Есть специалисты на Октавию А7 активироввать полезные фишки)
:bc:машинка не заводиться...что делатьАдрес 01: Электроника двигателя (J623-CBZB) Label: 03F-906-070-CBZ.clb Part No SW: 03F 906 070 JH HW: 03F 907 309 AB Компонент: SIMOS10.12AH10 3614 Ревизия: --H10--- Серийный номер: 00000000000000 Кодировка: 001900D6230400080000 Мастерская #: WSC 80093 222 69422 ASAM Dataset: EV_ECM12TFS02103F906070JH 004004 ROD: GV_ECM12TFS021PQ36.rod VCID: 71E229DDA081C5966BD-80241 неисправность:6260 - Блокирован блок управления двигателя P1570 00 [173] - - Индикатор неисправности ВКЛ - Подтверждено - протестировано после удаления записей Стоп-кадр: Статус неисправности: 00000001 Приоритет неисправности: 2 Частота появления ошибки: 16 Пробег: 68013 km Дата: 2027.14.15 Время: 00:33:51
17978/P1570/005488 - Engine Start Blocked by Immobilizer Possible Symptoms Engine starting but stalling immediately Possible Causes Key(s) not matched Instrument Cluster not matched Engine Control Unit (ECU) not matched Engine Control Unit (ECU) Power Supply faulty Possible Solutions Check for Fault Codes in Immobilizer itself (part of Instrument Cluster in many cars, but separate Immobilizer Control Module in some) Check Immobilizer Measuring Values (usually in Instrument Cluster OR Immobilizer Control Module) Match Key(s)/Instrument Cluster/Engine Control Unit (ECU) Check Engine Control Unit (ECU) Power Supply (Relay) Special Notes In case of Engine Starting Issues please make sure that you are really experience an Immobilizer related Problem! Even if the Immobilizer engages, the Engine will still start fine but cut out after 2-3 Seconds. If you are NOT experiencing this behavior (e.g. Engine doesn't start at all) your Problem is very likely NOT Immobilizer related. May be stored in Combination with 01176 - Key: Signal too Low in Immobilizer Control Module. If no other immobilizer related fault codes are stored and the immobilizer related meas. blocks are fine except Engine Start not allowed, on rare occasions it helps to try cold-booting the car. Remove both battery cables from the battery. Short the battery cables together (away from the battery) for about 15 seconds. Reconnect the battery. (Example) Low battery voltage (including a faulty battery) may cause Immobilizer system malfunctions and testing should be done only with a known good battery installed.
можно ли васей сделать так, чтобы при включении ближнего света выключались передние габаритки?
http://s019.radikal.ru/i615/1511/ea/4bf08d1ebd5b.jpghttp://s009.radikal.ru/i309/1511/e9/f4c33453f042.jpghttp://s015.radikal.ru/i332/1511/1c/75ae26fcfde9.jpg
Для ссылок на фото есть специальный тэг.
